I think i can make it work...
!http://farm4.static.flickr.com/3149/3062963195_5597337cc3.jpg?v=0!
55mm stroke! I got the crank too! 56mm bore!
hahaha i love the video. i work at a skating rink. thats hilarious.
oh and by the way. good luck.
What is that cylinder from? Will it fit under the moby tank? It seem quite a bit larger on the outside than the AV7 cylinder. Good luck!
I dont think so.
Now prove me wrong.
lol, what is that sillyness?
Looks like "half" a yamaha RD350 top end. I have no problem with exotic top ends... but you'll need a custom crank, custom engine cases, and a shite-tonne of other 'accoutremounts' to make that happen. Best of luck!
a yamaha RD350 is my dream
u need some work to make it work
good luck losing a year of your life to be the fastest :P o and even if u can get the cylinder under there the intake still has to go on which looks to be another 3 inches out of your frame
not an rd250 cylinder, rd's had reed induction
Correct, Its not even yamaha, its one third of a kawasaki basket case engine. The cranks press together
2"x6"x12" 6061 $92 on Mcmaster...
you shoulda bought the whole bike, those kawasaki triples are nuts
i was given most of the whole bike, in boxes, lots of boxes, and one of the jugs is not salvageable, again i said, most of the whole bike
I don't consider kawasaki triples that great. I don't like scary bikes. :-)
The GT380, GT550, and GT750... now those are solid bikes. Now you all have me wondering about putting a GT550 block on the peugeot bottom end.
The yamaha r5 was the model before the rd. Same motor but 5 speed instead of 6 and it was piston port.
I had one. It was amazing.
