What carb for a 64cc Sachs kit???
I just bought that 64 autisa kit from treats for my g3. Should I use the stock 12mm like it says in the paperwork that came with it? I have a 17mm magnum x bing that i would like to use but i just dont know if thats too much. Thanks!!
Re: What carb for a 64cc Sachs kit???
bump
on mine the 12mm did not work well at all.
I have it on a 5051D and have a 14mm but think it still needs more
fred
Thanks fred! so did you use the kit on the D motor????? thats what i have and some people say with the longer stroke it doesnt work.
ive got that kit too, am going to put it on a 504 with the short stroke.
I was gonna run a 505/d 14mm manifold the other way and try and run a dellorto. we shall see.
we shall probably see each other in the repair section asking about cluches is what we will probably see lol.
I put it on a 504 bottom end with the 505d intake and a 16mm Del. !7mm will be fine. Had to run a really thick gasket to get the piston to clear the top. Nice kit.
