Re: Re-Using Polini Soft Seize
MarkRyan /
you can also use naval jelly/phosphoric acid. and having siezed a bike shouldn't increase your likelyhood you'll sieze again. in my experience mopeds are very forgiving.
also, i know this sounds like crazy bandit talk but you should try to salvage your old polini piston and rings. i've taken hard siezed (rings stuck in the grooves-piston scored as fuck) kits and completely saved them, got them running with good compression. sand the fuck out of the rings (as long as they are not snapped) and the piston and run it. i know it sounds like a terrible idea but i've seen it work well. its free try it. or if you really don't want to do that sell me your fucked rings and piston!
  Re-Using Polini Soft SeizeTopic by: Josh Schutz Josh Schutz 11/25/08 08:50PM
  Re: Re-Using Polini Soft SeizeRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 11/25/08 08:57PM
  Re: Re-Using Polini Soft SeizeRe: terrydean is tony who is tony? terrydean is tony who is tony? 11/25/08 08:57PM
  Re: Re-Using Polini Soft SeizeRe: Josh Schutz Josh Schutz 11/25/08 09:05PM
  Re: Re-Using Polini Soft SeizeRe: terrydean is tony who is tony? terrydean is tony who is tony? 11/25/08 09:06PM
  Re: Re-Using Polini Soft SeizeRe: Josh Schutz Josh Schutz 11/25/08 09:12PM
  Re: Re-Using Polini Soft SeizeRe: MarkRyan MarkRyan 11/25/08 09:29PM
  Re: Re-Using Polini Soft SeizeRe: ) Cupermcnewbster ( ) Cupermcnewbster ( 11/25/08 09:34PM
  Re: Re-Using Polini Soft SeizeRe: SABAT! andDestroy SABAT! andDestroy 11/25/08 09:38PM
  Re: Re-Using Polini Soft SeizeRe: terrydean is tony who is tony? terrydean is tony who is tony? 11/25/08 09:43PM
  Re: Re-Using Polini Soft SeizeRe: jak stoll jak stoll 11/26/08 12:01AM
  Re: Re-Using Polini Soft SeizeRe: Responsible Jon Responsible Jon 11/26/08 01:58AM
  Re: Re-Using Polini Soft SeizeRe: Col Orrell Col Orrell 11/26/08 03:09AM
  Re: Re-Using Polini Soft SeizeRe: peter peter 11/26/08 03:37AM
  Re: Re-Using Polini Soft SeizeRe: mikegeez mikegeez 11/26/08 10:22AM
  Re: Re-Using Polini Soft SeizeRe: ***VANILLA BLUNDER*** ***VANILLA BLUNDER*** 11/26/08 01:40PM
  Re: Re-Using Polini Soft SeizeRe: elliot elliot 11/26/08 01:59PM
  Re: Re-Using Polini Soft SeizeRe: peter peter 11/26/08 02:11PM
  Re: Re-Using Polini Soft SeizeRe: Seattle Tony Seattle Tony 11/26/08 02:23PM
