Is this Treats High Compression Head any different than the stock head on my 2 speed ZA50 Magnum MKII?
yes, the squish band is alot better
Squish band? Will that make it faster?
add this to a stock cylinder for increased compression, and a subtle increase in all around power
right from the treats web page
it will boost compression a good amount and with a swuish you will have better combustion
It is not the same physical size as your Magnum head, if you put it on your stock jug it will work fine, but look stupid.
do you need a kit for those high comp heads? i thought it was just like an add on to some kit you buy or already have. or is it like a lot of moped stuff: suck it and see...
aka DIY and check it out.
no you dont need a kit, it fits a 50cc puch be it stock or aftermarket cylinder i have one i am about to put on my magnum but its been pretty cold i think il go do it now
very cool. do they make this kind of head to bolt on a stock peugeot?
yes
i just bolted mine on and went for a short run and it deffinatly had more power altho it was only a short run since its so damn cold i think im now running rich tho idk it wont rev out maby my 18 x 36 gearing is too much? it wont rev out on the stand either tho well not as high as my batavus used to its like 6k if i had to guess sounds like it hits a point and just stops, did it before the head swap to running stock 12mm carb with different jet, adjusted needle and za50
why spend $30 when you can just sand down your stock head for the cost of a couple sheets of sandpaper and an hour of work
i just did my stock cobra head i sanded it down till it was straight across even with the fins
threw it on and now it has some fuckin torque
i might take off another few thousadnths
the high comp head will still have a better squish band than a stock, milled head.
thas what i'm thinkin. also: do you have to modify the piston in any way?
no
I use the side of my 14 inch cutoff wheel for this
cuts them in like 5 minutes :-)
wear gloves the head gets hot :-)
take care
JAK
Afraid I will f*&% it up, $30 aint much if I get something for it performance wise.
Hmmm, higher compression = more heat? Isn't that why the fins ar bigger? How much performance can I expect for my $30 investment?
its worth it IMO and its more like 38 dollars unless u live near treats
you will run richer becuase of the less room in there now .
you down jet 1 or 2 with a high comp
