I need this F#&%ing Peugeot spring
I wanna give this engine return spring a try I saw it referenced to for the first time in a Malossi diagram but couldent find a part number for it Heres a clear view of it about 30 seconds in.
Re: I need this F#&%ing Peugeot spring
that guy is an idiot. pulling that wire out is a great way to kill a cdi unit.
Yeah it's totally true but fuck his CDI i want his spring
make one.
wait....do have a Peugeot?
the g2 pipe is mounted on the wrong side and what the hell is that in its place?
Nevermind. It's the kickstand, on the wrong side.
Oh get the doppler spring, it's adjustable and helps with stretched belts, and it's red.
Yeah but its also a hundred bucks as compared to about 50 for a polini spring. But then again it looks sturdy as a mother fucker.
if the polini one is adjustable get it. But I dig my doppler spring. You can adjust the length of it for belt tension but you can also adjust the spring tension for variating. I don't have to switch out my weights if I want it to variate at different speeds/rpms.
so folks who suggest making one, got images? how to's? i'm totally interested cause i feel like my dellorto is sitting a bit too high.
