so i normally don't post and try to find this however i've searched and not found much.
working on a puch where i basically built it from the ground up.
starts and runs.
idle sounds good.
however when i start out the bottom end is slooooow.
it's not boggy from too much gas, because it doesn't sound like it and it doesn't shut off.
It does take forever to get going from a stop, like its winding hard or something? if that makes any sense.
once i get going, it speeds up well and then i can feel my pipe kick in even and haul ass.
after i ride if i pull the plug and look at it, good color.
just a little bit boggled.
im running:
e50, polini, 16 phbg, all new seals bearings internals, racing crank. malossi filter, simonini, 3 shoe clutch (paz springs)
phbg tuning issue? clutch tuning issue with springs?
if that helps any. any suggestions would be helpful.
first build and still learning :)
