I have noticed that most two ringed set ups have the pins and the ring gaps on the exhaust side. ( Most, meaning allthe ones Ihave in my garage.) The super 50cc AV10 has two rings and they are on the intake side.
Now this is where you all can tell me my idea is wrong...
Yes even with the malossi 50cc screamer kit I'm still playing around with my spare AV7 jugs.
The Goal: to stick a reed in the piston port intake.
The Question: How bad would it be to turn my AV7 piston 180 degrees in the bore to put the ring gaps on the intake side.
p.s. don't ask no more questions of how i intend to stuff the reeeds in there or the holes i'll have to cut in the piston...
thanks
fire away
