Re: wrist pin/needle bearing damage
New york Doll /
Drill holes like lee said ...you can do it with motor together ...3.00 cobalt drill...slow speed on drill press !!!...it will smoke half way through if you don't have constant cutting fluid...if you "work harden" you will have too dremel with diamond bit (harbor freight) do it all time just takes a little finesse...once you get through dress up inside of rod/oil hole with ball bit you get in the diamond set 3.00 onsale...you cannot use a old wrist pin with new bearing or vice versa...Elliot is correct about the quality of wrist pin bearings... Crap!!! I am lucky enough to have a stash of old SACHs german one's but im runnin low...Got a few og derbi ones too (awsome)...Good luck...ooh almost forgot along with holes in piston boss ...look at a brand new A55 piston with parallel oil slots carved in it ...I do that to every piston
  wrist pin/needle bearing damageTopic by: Brand I eat a treat Brand I eat a treat 11/11/08 11:10PM
  Re: wrist pin/needle bearing damageRe: Jon P Jon P 11/11/08 11:26PM
  Re: wrist pin/needle bearing damageRe: coco coco 01/16/09 06:38PM
  Re: wrist pin/needle bearing damageRe: Aces Brother Aces Brother 01/18/09 09:36PM
  Re: wrist pin/needle bearing damageRe: elliot elliot 11/11/08 11:36PM
  Re: wrist pin/needle bearing damageRe: elliot elliot 11/11/08 11:37PM
  Re: wrist pin/needle bearing damageRe: Flagrant - Flagrant - 11/11/08 11:43PM
  Re: wrist pin/needle bearing damageRe: Brand I eat a treat Brand I eat a treat 11/12/08 12:06AM
  Re: wrist pin/needle bearing damageRe: moon doggie moon doggie 11/12/08 12:39AM
  Re: wrist pin/needle bearing damageRe: noah on e noah on e 11/12/08 01:22AM
  Re: wrist pin/needle bearing damageRe: I R E Rick I R E Rick 11/12/08 01:26AM
  Re: wrist pin/needle bearing damageRe: Aces Brother Aces Brother 11/12/08 03:06AM
  Re: wrist pin/needle bearing damageRe: moon doggie moon doggie 11/12/08 03:16AM
  Re: wrist pin/needle bearing damageRe: Aces Brother Aces Brother 11/12/08 03:20AM
  Re: wrist pin/needle bearing damageRe: moon doggie moon doggie 11/12/08 03:37AM
  Re: wrist pin/needle bearing damageRe: moon doggie moon doggie 11/12/08 03:45AM
  Re: wrist pin/needle bearing damageRe: Aces Brother Aces Brother 11/12/08 03:56AM
  Re: wrist pin/needle bearing damageRe: moon doggie moon doggie 11/12/08 04:28AM
  Re: wrist pin/needle bearing damageRe: Brand I eat a treat Brand I eat a treat 11/12/08 12:53PM
  Re: wrist pin/needle bearing damageRe: moon doggie moon doggie 11/12/08 01:18PM
  Re: wrist pin/needle bearing damageRe: Graham Motzing Graham Motzing 11/12/08 04:15PM
  Re: wrist pin/needle bearing damageRe: maciek maciek 11/13/08 06:52AM
  Re: wrist pin/needle bearing damageRe: weeder weeder 11/13/08 01:23PM
  Re: wrist pin/needle bearing damageRe: Flagrant - Flagrant - 11/13/08 01:03PM
  Re: wrist pin/needle bearing damageRe: Responsible Jon Responsible Jon 11/13/08 02:05PM
  Re: wrist pin/needle bearing damageRe: maciek maciek 11/13/08 02:49PM
  Re: wrist pin/needle bearing damageRe: Flagrant - Flagrant - 11/13/08 03:20PM
  Re: wrist pin/needle bearing damageRe: maciek maciek 11/15/08 06:22PM
  Re: wrist pin/needle bearing damageRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/15/08 08:52PM
  Re: wrist pin/needle bearing damageRe: Bort Hoff Bort Hoff 11/15/08 09:02PM
  Re: wrist pin/needle bearing damageRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/15/08 09:44PM
  Re: wrist pin/needle bearing damageRe: maciek maciek 11/15/08 09:57PM
  Re: wrist pin/needle bearing damageRe: New york Doll New york Doll 11/15/08 10:26PM
  Re: wrist pin/needle bearing damageRe: maciek maciek 11/15/08 10:56PM
  Re: wrist pin/needle bearing damageRe: Kansas John Kansas John 11/15/08 11:02PM
  Re: wrist pin/needle bearing damageRe: Phaedra Phaedra 11/16/08 12:06AM
  Re: wrist pin/needle bearing damageRe: jak stoll jak stoll 11/16/08 12:28AM
  Re: wrist pin/needle bearing damageRe: maciek maciek 11/16/08 01:02AM
  Re: wrist pin/needle bearing damageRe: MarkRyan MarkRyan 01/16/09 08:42PM
  Re: wrist pin/needle bearing damageRe: MarkRyan MarkRyan 01/16/09 08:46PM
  Re: wrist pin/needle bearing damageRe: Joshua Franta Joshua Franta 01/16/09 09:10PM
  Re: wrist pin/needle bearing damageRe: Jimmy Stucky Jimmy Stucky 01/16/09 09:52PM
  Re: wrist pin/needle bearing damageRe: MarkRyan MarkRyan 01/18/09 09:54PM
