i know what you guys that are saying the pin does not move in the piston are coming from, once everything warms and expands the piston holds it tight, but why the oiling holes then? i think these might not work like that, i know automotive pins are way harder to drive in, have to heat the piston in an oil bath to over 100 degrees F for the pin to slide around in both my VW and Mitsu engines..
