Bing needle jets - differences? how many?tapering?
I want a bing needle that is richer than the one that comes in the 15mm but will fit the 15mm
does it exist?
The needle in my 14mm looks the exact same - . I find it hard to believe its any different.
has anyone messed with the tapers?
Re: Bing needle jets - differences? how many?taper
i dont think the needle itself will make much of a differ id change the needle jet
the needle is the needle jet
Yes, you are correct. So let's open up the discussion to needle jets too.
ok
cehck this out and dioscuss does it apply to bings
Get a 2.20 needle jet (the piece the needle slides in) They came on some Puch and Pinto carbs. You can order one from BJ at Handybikes last I checked. It will richen up the idle and from there on up to 3/4 throttle. You will end up running your needle in a higher notch compared to now. I had to use one on my Polini to get it just right.
