Re: air leaks suck help
David /
Interesting. Is this a common problem with the cheaper kits? Hes tried all kinds of gaskets and ended up cutting some really thick ones for the base gasket. Like 1mm thick. Seems to be the only way to get the piston to clear the head. As far as the head gasket hes using the one it came with. Aluminum. Thanks for the help.
