Re: air leaks suck help
Chris Rice /
You buy some valve grinding compound at the automotive store... Then you take the glass from a picture frame and lay it flat on a table.... Then you squeeze out the valve grinding compound on the side of your head that mates to your cylinder. Place the head flat on the glass and in a figure 8 motion, run it with steady pressure. That valve grinding compound and the ultra flat glass will work out any uneven spots on the mating surface. When you are done obviously clean it up really good. That valve grinding compound can't get into your cylinder bore... :)
Are you using the head gasket that came with the kit?
