light bulb led conversion
my license plate light keeps buring out so i found a cheap solution.
i had a led key chain light that i use all the time so the battery went dead. its cheaper to buy a new light then it is to by a battery. so i took it apart and removed the led,its not even soldered in ,it comes right out. i tryied a 100 ohm resistor but it was too dim so i went with a 39ohm resitor and its nice and brite.and it draws much less voltage
Re: light bulb led conversion
here is a pic of it installed,i wish i would have save the old bulb .i would have soldered the led into the burnt out bulb
geez coco your like the god of leds. thats awesome. good idea
its nice and brite,no more burnt bulbs
I got some led's at superbrightleds.com. The 24 led bulbs are the most led's to a bulb in order to fit the moped light dome. And you can choose a wide or narrow span of light. That's what I'll be sportin for a while.
with those LED's from superbright, do they do okay with a kitted bike? i know some halogen bulbs can be overvolted and be alright, but i don't know if the 6 volt LED's could take the extra volts from a kit. Anyone had good results...
