Re: carb upgrade for tomos
Robert Rosselit /
The easiest and cheapest route is the Dellorto SHA. There are better carbs that allow for more adjustments so it depends on how much you want to get into it. They start with the Dellorto PHBG which not only comes in larger sizes but has multiple jets. Probably a step up from that would be Amal or Mikuni. Mikuni jets should be readily available at any motorcycle shop.
