If your are getting spark you don't need a coil. If you are getting mixture you don't need a carb. Plus the ciao carb is like the best protected carb next to the pa50, so unless its extensively rotten on the inside, you should be good. Just clean clean clean that biotch, but be very sensitive to the gaskets. Don't buy anything performance wise until you get it running right.
Re: New to Mopeds. Ciao advice plz?
