What size sparkplug for a A55 70cc Airsal?
So I can get one later today with a .069 main jet?
Re: What size sparkplug for a A55 70cc Airsal?
Oh yeah and what should the gap be set at?
John Joedicke /
Same as OEM plug.
im running a B6HS you can get B7HS im not sure about the gap and im running a 80 jet but B6HS are good
Same as OEM? I put the old plug in and it was too long.
you need a short one the B6HS is a short one
Your running a 80 jet on the stock carb? I have a 76 and 78 coming but I'm goin' to put a 19-21mm carb on here as soon as I get the money.
I run NGK B7HS or B8HS on kitted mopeds to keep em cooler... B6HS for stock bikes.
John, it's not the same as the stock plug. The stock plug on an a55 is a b6ES, the long one. On the a55 kit you need the shorter b7HS.
im running a 80 jet on a 17.5mm phva carb with a B6HS
