I just got a 15/15 for my puch but the throttle cable it came with doesn't fit into the throttle assemply on my handle bars. So i used my old cable and there is about an inch to much cable. I don't understand how to tighten it that much cuz there is no tention on the cable.
Dellorto throttle cable
Re: Dellorto throttle cable
you should be able to loosen it up and pull it through some more at the throttle to take up the slack, unless you have some other throttle..or try to add the adjuster elbow to the delly to add length, not sure if that works though.. pics?
Got ya, i will try to add the adjust elbow. I just dont understand why there is that much loose cable. I was thinkin of cutting the stopper cutting the wire and sotter-ing it back on but i figured that wouldn't work
Yeah, I ran into the same thing with my phbg, just use the elbow from the bing and you are in business.
And don't spam the forums.
