Milling intake 'port' in piston
Mars   /
I had an idea last night, and thought I would pass it by you all before I destroyed something experimenting.
I was thinking that if one were to mill out a half-circle shaped opening at top the base of the piston with the same diameter as your fuel intake, it would allow for more time for the engine to draw fuel into the crank case.
See attached picture for further explanation of what I'm thinking.
