16 phbg. using the reed valve that came in the polini box. is there anything that is going to be a noticeable difference. let me know what you guys like and use.
recommend reed valve for polini
Re: recommend reed valve for polini
unless you are absolutely tuned to the max with your current setup, there will be small if any differences.
check out the mallosi reeds.
