mind boggling suckage
so i have a fairly modified (for a 16 yearold) ped...
but something isnt right...
im only hitting 47mph tapped
its an a35 with...
70cc dmp kit
case matched
exhaust port matched with exhaust
simonini puch pipe
high comp head
could it be i have the stock intake? (13mm id) horrible sharp bends
have a 4 petal and 21oko that i am waiting to make an intake and reed block for (little winter casting project)
Re: mind boggling suckage
I think you hit the 13mm nail on the head...
don't burn up that kit!
k cool..
and would i see much gain after i get the new intake, carb, and reeds if i widend the ports?
any other little things like shaving the piston? (<--- how do you do that btw?)
jeezus, how do you afford all that shit at 16? i could barely afford weed each week.
benji is my pusher man.
i screenprint tees to get cash. (i made something like $196 2 weeks ago)
i hustle moped parts to get better ones... like my cylinder and carb and intake for the new ones.
i am helping with wiring my moms house for mexican wages as well...
and sometimes if i am friendly people are super friendly back like the guy that welded up my pipe (thanks danny gill!)
but back to my problem
anything else other then intake?
what about piston shaving?
port widening? rising and lowering?
ignition advancing?
tri turbo or super duper charger? :P
Intake is your literal bottle neck at the moment. Everything else is putting the cart before the horse at this point in time.
I'd say your doing pretty good thru a stock intake and carb. Are you also running the stock gear ratio too.
that intake is poo.
Its the gear ratio! For sure. If your only compaint is 47mph, then just gear out. That's what all the Puch tuners who are getting up into the fifties are doing.
nah bret... my friend has a 70cc piston port kit on his a35 and he is running the same gearing i am and he is hitting 55ish with 15mm carb and intake and biturbo
i dont have any lowend either..
could be the pipe, but i think it has to go with the intake again....
could i do piston shaving?
ignition advancing?
to get more?
trying to get the most out of this like most of the tuners here lol
🇮🇹💦 Of the Loin /
its your intake dude. and the tiny carb.
sweet!
im about to fix those...
now can i get answers about piston shaving?
ignition advancing?
Get the new carb and intake dialed in before adding something else to the equation...
good idea.
but any info on anything?
what is the biggest performance gain?
🇮🇹💦 Of the Loin /
biggest performance gain? new carb and new intake.
then work on everything else. after the carb its all gonna be small gains anyways. the carb will be a huge gain.
but wait! what about:
ignition advancing?
oh and dont forget:
ignition advancing?
Thread hijack:
How critical is it to run a "performance" pipe after installing a larger bore kit? Sometimes I hear that it will not hurt performance that much, other times I hear that it will massively ruin performance if one runs a stock pipe.
It's just a total waste to go through the trouble of kitting a bike, and then holding it back with the crap stock exhaust.
can i get some answers to my questions?
please
scratch that...
and yeah noah i want to know. lol
i am super pumped to get my carb mounted...
anyone have any ideas on my top speed? could it be 60?
p.s. i have a 27th front (one more then stock)
may go to a 31 if i have the lowend to handle it...
