i bought a 16 sha from some guy it had an 80 jet in it figured it was cool, put it on my a35 with pipe an 70cc cranked it over a few then it reved like a bitch then died. when i got it to stabalize it was still reving high and soon as i let off the throttle it dies. and it does not wanna run with out the choke. any ideas?
Fucked up dellorto
Re: Fucked up dellorto
that jet is WAAAAAAAY too small. get up in the 90s son! it's a 70cc. you're headed for cylinder damage running that lean.
running lean probably.
Upjet for sure. What air filter are you running.
Also sounds like you might have an airleak if it revs high at idle by itself.
upjet or put a more restrictive air filter on.. Sounds like you're getting too much air, or not enough fuel.. Possible air leak too.
Are you sure that the slide is dropping all the way to the bottom of the carb body? There should be about 1/16" slack in the cable when the throttle is closed all the way
the part where the fuel line hooks on was super cracked open its fine now and have up jetted
awesome.
