Re: Need a complete parts list for upgrades to 78
elliot on bella /
yeah basically ur right, thats a good kit too, watch out tho the exhaust studs are welded in and like to snap under a heavy hand.
the new top end and piston will all fit together without modification on a 2 speed i believe. however u might need to trim the cylinder skirt a bit and or add base gaskets to make it all work out (sometimes 2 speeds need that with kits)
use either a 14mm or 15mm bing carb with that setup, as for jetting get a range and tune the bike into the perfect one, all bikes and setups are slightly different so there is no magic number, i'd say get the 70's range jets for this setup, but someone else with more metra 65 experience might know more.
good luck
