help on improve my mod bike
ok so as of now i have a 2006 arrow r with an airsal 70kit 66 main jet carb upgrade kit and uni pod. I just ordered a dmp adjustable filter and the upgraded carb. the upgraded carb is the stock carb bored out to 17.5 mm. So now i was wonering what else i could do to increase speed on top is there any smaller rear sprockets for a 2006 tomos arrow. the sprocket is different than the other tomos one beacause it has a smaller hole with spline.
Re: help on improve my mod bike
roadent$ craig /
you need help on improve your english
sorry help on IMPROVING my mod jesus i was typing fast
A 66 jet sounds a bit lean to me..
you can get larger front sprockets as well if you cant find smaller rear. if you get the biggest one they make. the 31. you will have to switch to a35 ignition and grind your case.
why switch to the a35 igniton and by grind the case u mean like dremel is casue the chain will hit it ?
yup and the ignition on the a55 prolly gets in the way
oh ok thanks man ya i would rather not grind the case ya kno what is the stock front sprocket????
and the a55 ignition retardes your shit
sammy doesn't mean it causes a cognitive disability in your moped. the a55 ignition limits your top end big time.
(apparently) the a35 ignition doesn't do that, so you might bet better top end from it.
is that proven at all yet? like has anybody put a35 ignition stuff on an a55?
im pretty sure SABAT! has...
lmfao~;O>
22 tooth aye? that's what i got but I'm not putting her on till I figure this JB weld in the Airsal kit out. I got a ST btw. Might be the same, should anyway. I failed english too fuck 'em.
o' course I was skipping and fuckin'~;)>
ahahahh ya so how much will it help to use a a35 ignition and any links for one?
well a55 self retards and slows u down after 12rpms so if u want to get over that u will need a different ignition.
on up the carb with sproket chain's it will help.
so do i have to get a a35 ignition or just an a35 cdi box????? ino on my quad i bouthg a rev box a higher revving (cdi box)
a35 ignition i think as it is points not cdi.
yeah, dean is right,
up the front carb with sprocket timing the ignition impulse delay.
ok so i have to buy a complete a35 ignition and what will i have to to in order to hook it up
idk probably just hook up the wires and bolt on
don't arrows have little scooter wheels? larger diameter wheels will also change your "gearing" giving you more top end. but I don't know what fits on those things.
ya they do but i dont want to change them i love my litle wheels nice and wide
anyone know where i can get an a35 ignition
why is your name Tomosmodder if you don't know how to mod your Tomos?
oh and looking in the buy/sell forum would be a good start.
you can get a a35 ignition and stator from a a35 engine.
find one. take it apart get that shit to work and viola.
