air filter recomendation
ok so i have a 06 arrow with a 70 kit high flow filter and techni gas and i am running a 66 main right now. So today i went to ride my ped and when i let off the throttle is wasnt steady like rpm's. So imlike wtf. Then i look and the grommet on my airfliter is ripped from the clap "cutting" through it. So obviously this is what is doing it the in balnce of air flow. So i was wondering what i could get for another air filter either the uni pod or malossi or the tunr filter, or the dmp tunable filter.
Re: air filter recomendation
bump
uni pod
k thanks i order another uni pod and a tunable dmp. I also fixed my other uni so this way i can run uni's on boht my 06 arrows and have thetunable as another option
panty hose
isnt panty hose too much airflow
or should i just do somthin like that and jet up like hell till i runs good. cause correct me if im wrong with somthing as "flowy" as panty hose i need to jet up alot right
you can do like two layers of panty hose.
do a plug chop to see if you need to upjet.
On a stock vespa with a pipe I went from a 50 to a 52 when I switched to two layers of pantyhose. BTW: SF, sea level.
Ya so along with those filters i ordered im gunna make a "filter" from a cut up pod filter and do like panty hose filter then pantyhose
