Carb jetting PHBG vs. SHA
So I've decided to go with a PHBG instead of my stock 14mm SHA.
For two obvious reasons:
- Larger bore (16mm)
- More tuning!
I'm curious as to where I should start my jetting at for a new pipe and air intake compared to my SHA. I'm curious as to whether or not it's safe to say that the main jet should be the same in a PHBG as it was on my SHA.
So far I have no idea where to start. I've looked at the tuner sheet, but there's nothing on there for Minarelli V1's running stock CC with a PHBG.
I know there's 100000390849038 threads about jetting help. I was just hoping maybe there's someone out there that hasn't put their setup on the sheet yet that has a similar build as mine.
Thanks in advance!
Re: Carb jetting PHBG vs. SHA
My 2 cents is how big is the phbg you dont want to over do it
she said it was a 16 phbg. i would guess around 60's for your main jet and i would for now leave your other jets stock with the carb. phbg and sha use the same main jets. good luck. i know sha 16s come with a 70 main. not sure about phbgs. hope this helps
i say start at about 70 and go down
roadent$ craig /
stacy. i got a shit load of jets that i dont use... ill let you borrow them.
Sweet, thanks Craig.
And thanks for the help.
By the way, I'm a guy lol.
shhhh! no one will help you now!
Hey dudes did you get the stator assy i sent ya yet?
