Re: Sachs Kit ? and Intake ?
SchijnHeilig /
That wedge spacer is for a different type of manifold that goes onto a differently shaped intake on the cylinder. Not really necessary as you seem to have the "square" intake. I don't think you can use it to flip your intake around, but you can try. Maby it works.
I'd have a custom intake made for a 18mm or 20mm Dell'orto. Will make the kit perform so much better.
