I'm pissed. I just spent way too much time trying to make my custom intake fit on an a55 airsal kit (this required first opening up the holes so bolts would align, then finding the right bolts because studs wouldn't works because the holes are so closely spaced so I found some allen head bolts, but even those were too wide/long, so I cut them to length and filed them so they worked, and also grinded the heads of the bolts so they are super thin, so I finally got the intake on). So I get the intake on, make some fresh gaskets so this bitch will mount up on my za50, I pull off the old cylinder, carb and pipe, and throw on the airsal piston and cylinder. Before buttoning it up I turn the flywheel like I should and FUCK, the piston hits inside the case. Why??? I had a a35 alukit on there which is like 67cc's and are you really telling me this 3 extra cc's make the piston so wide it hits the nubs in the case? Apparently yes.
So now I'm mad. It also turns out my double hacked simo isn't going to line up to this kit. A55s have an angled port a-la metras and gilas while a35s are even more extreme angles. So now I gotta find some other pipe and other stuff.
I need to ride a damn moped now. Fuck. I've wasted my time on pointless shit.
