Re: Fuck Mopeds!
Klen Kahdidlehopper /
If the piston is hitting inside the case then all you need to do is a little grinding. No big deal really. Just take the cylinder off leaving the piston on the connecting rod and turn the crankshaft to bdc. Look to see where its hitting. Then take the piston off and cover the exposed crank with some cloth. Really push the rag down in there. Then using a vacuum to suck up the shavings start to grind away. It probably wont take much grinding. When all the grinding is done use a compressor and some carb cleaner to clean out any remaining shavings. I used the previos mether to bore out a za50 for a gilaradoni 80cc kit. I never even split the case open. Hope that helps.
