Has anyone swapped carbs on a chappy with a polini 70cc kit and ninja pipe and other mods??? Just wondering what works the best to save some troubleshooting time.
Thanks,
Nick
Thanks,
Nick
I'm using a 21 phbg (you have to get the larger polini intake.
It fits fine but the side adjustment screws are kind of tough to get to. I use a malossi e12 intake and you can fit the center cover over but it bulges a bit.
oh ok i see.... what would i order the intake for? and where cani get it? Are you mixing yours or are you using your stock oil injection?
Oil injection removed. I got the intake from benji (treats) along with the kit and a gianelli pipe. If you get the intake, get a clamp on phbg, NOT a spigot.
I'd probably run a 19mm phbg if I were to do it over.
ok thanks man! hopefully everything works out!!!
