Running lean will also cause backfiring. Upjet, and yes, double check your timing. What kind of head are you running? If your compression ratio has been increased you may want to advance the ignition timing a few degrees.
Most dirtbike shops have 6v Regulators available for cheap. Quite easy to install. But, yeah your blowing bulbs because you've eliminated the taillight.
