you need to put o-rings in some of them, usually more dependant on the intake manifold than the carb itself.
Jt,
its almost certainly your ignition. dirty points, weak coil, wrong timing, sha's usually run lean in the low revs, in my experience. make sure your points are clean clean and set at stock, you'll probably have to retard timing.
