like the one from quarterkick, i wanna know if u ran into any problems, if so what were they, how fast are u going with your currect setup and was it worth it, thanks
FUCK THE PARMA KIT
stupid steel sleeve....i had to hone that shit and decarbonize it EVERY MONTH.
Not only that, see how there are no fins near the exhaust? it caused so much overheating and scoring (even after adding copper piping to cool it) that i just junked it.
the one positive...it had some decent torque...when it ran
terrible idle as well (due to so much scoring!)
Get an athena, its like 160 if you can find it and WAY better in all aspects
-Shadow
Its a great kit!
I don't know WTF Shadow is yacking about, but its a plated cylinder.
It will require welding on your cases, there is only 1/32" overlap at the base next to the transfers.
After 1300 miles, the roller bearing walked out of the wrist pin and disintegrated
https://www.mopedarmy.com/forums/discuss/read.php?f=7&i=97082&t=97077&v=f
Did your piston have any holes in it? If it was plated it wasn't the same kit.
-Shadow
Yeah i looked at the other thread....yours had boost ports just like my athena, my parma piston was solid, no holes at all. Where did you get your parma?
-Shadow
shadow there were two different parma's...you got the bad one apparently.
i like mine.
Casematched E50
70cc Puch Parmakit
Hi-Comp Head
20 mm intake
20 mm Dellorto PHBG
Malossi Hi-Flow Filter
Tecno Estoril
16x45 (I think...is 16 stock on E50's? stock up-front)
running an 86 jet right now, i think. needs to be dropped maybe one more size. idle jet is a 60, that definitely needs to get dropped a bit.
with tuning it should hit 50.
oh ya, stock three shoe clutch that needs to be further tuned too.
yes i am interested in where you got the different parma...it seems very similar to the athena
i definitely had a shitty experience with parma, but if they have other good kits i would like to know more about it so new people don't have to find out for themselves.
-Shadow
quarterkick.com
I wanna know about that 75cc one that '77 has based on the magnum cylinder... looks cool. (Too much $$ though.)
The parma kit hasn't been explored enough. It has a fucking ton of potential but the only one to touch it was shaw. With what he did to it made it awesome and could topple metra's for sure.
Granted its shaw. But people don't explore the possibilities enough.
fuck a polini.
wrong parma noah.
fuck a polini? fuck 65cc and faster than metra 80s and gilas?
no thanks. I like going fast.
polini isnt faster than gila.
we just know about 2-3 years more info on polinis.
My girls tomos alukit will blast 95% of polinis with fairly mild porting and a boss pipe. If you are getting blasted with a polini with an 80 metra or gila you suck at mopeds and should quit.
I just got my motor back together after some MAJOR port matching to my Parmakit, my transfer ports dont look like anything ive seen on any other Parma's, they are f-ing HUGE. Definitely had to get additional material welded on. I bought the thing used and the guy before me actually ported it a bit, Devin from Motion Left said he wasnt sure about it, but I figured i'd go ahead and try it out. I am still in the process of tuning it (20mm PHBG) but it seems to be doing pretty okay so far. Im running a Boss on it and it takes a bit to get up to about 15 right now, but as soon as I hit ~15 it takes off like a rocket.
It does seem like the RPM's are a bit high so I got an 18t sprocket for the front just to see what happens.
BTW, I am also running a 70cc High Comp head.
So yeah, fuck a polini.
As far as parmakits go, I dont have any expereince with the 70cc kit, but there stuff is good quality in my opinion. Looks to have some massive transfer ports too. I would expect decent results.
i guess people suck at tuning. Only a handful of gilas/metras passed me, and I know I passed a ton of them. I'm not really sure what that says. Well I do know what that says but yea. Tune your shits!
Parma looks like a ton of potential, very similar to TCCD and others.
Yeah, I thought it was another tccd knock off till I saw the gigantic transfers.
Dont get me wrong polinis have tons o potential if tuned right, but for the money they cost now, and the reliability factor is say fuck a polini. And yes, most people with big boy 80 kits dont know what they are doing with them.
shadow, i got mine from treats.
yea, i havent done any porting on the parmakit yet, but i'd like to.
If you think of displacement a polini does really well, The metra's etc do not, 80cc should be doing 70mph to 80mph right? If you measure it by the same bar as the polini. Tommy managed to probably get the most outta his 80 kit, most of the rest of them are probably not running to there full potential. Anyways just my 2 cents. But then the displacement is often not a true to size as well. My point is it's kinda hard to compare apples to oranges. When it's piston port vs reed vs a large displacement vs a smaller displacement.
Without a doubt my gila is getting %15 of its potential. I am on the side with Tommy as in people don't know how to tune (IE me) I realized after the rally that my point gap was shit. Fixed it and now is back in business. Fuck a nice flywheel cover.
Totally nothing to do with parma.
like I said. I am not taking anything away from polini. They make a ton of power for what they are. I only say fuck a polini for their $300 price tag and unreliability. There are atleast a couple a35 kits you can get for much cheaper and throw on an e50 and get just as much out of for much cheaper.
Also, as far as top end goes, you don't gain that much with bigger kits. Looks at shaws 65 mph 50cc a35, compared to my 70 mph 75cc metra. Bigger kits get you a lot more torgue and a little more top end. At that point it's coming down to gearing and wind resistance. That said, I honestly believe I can do 75 on a 75cc gila. Lots of work to do to get there though. Maybe it's just a crazy dream, but I think it can happen.
I think the unreliability of polinis is just a claim that has come from numerous people throwing them on their bikes, not jetting it right, then seizing. Maybe I've just had good luck, but I've put hundreds of really hard miles on my polini and only soft seized it once, and this was totally user error and could have been prevented (spark degrading over time -- check ups would have led to an early fix). Since then I got a new ring and I've put many more very hard miles on it with ZERO issues. Last weekend we rode about 60 miles of mountains, and I'd say I did 95% of it at WOT. During the saturday ride of gender bender I rode from the coffee shop to the top of twin peaks basically as lean as can be; no air filter. This was not on purpose, but it was probably a good 5-10 miles at the front of the pack, and no issues. Also, why would you pay $300 for a new polini when you can get a usable seized one for less than a new tomos kit?
I think those who are scared to run all out, all the time, first need to get some better tuning basics and some confidence. Sure mopeds can be sensitive, but if you are jetted properly, they can take a shit ton of abuse.
yah that saturday ride gave me new confidence in how tough my little Ciao is. its not kitted but that was the longest ride I had ever been on, I thrashed the thing and it never skipped a beat. my roommate took it on the long Marin ride... Same story.
holy jesus, those are definitely some big ass transfers.
home is where you make it
you like to see homo's naked?
for some reason i wanted to quote that.
but tuning plays a part in every single kit. my stock maxi will keep up with mk65s and even a badly tuned, badle geared mk80. thats just cause i tuned mine right. to a T. i can also keep up with an 08 street mate until a certain point.
mind you, this was all on an open port stock cylinder. just spend some time, get your shit dialed in, and blast.
as for me, ill be kitting soon, with a cheap kit, which i will prove that you dont need a 250$ kit to blast. and ill do it reliably.
what we need is more knowledge, and less kits. do over 40 on a stock jug, thats where the fun is, trust me ive done it.
a kit is just a chunk of metal with a hole in it... anything can be ported to do anything, within reason.
that said, the parmakit is fuckin' awesome.. you dont have to weld up the transfers, but you do have to be dead-on-balls accurate when you case match and when you assemble the engine to make sure you dont get it off to the one side too far.
I helped adam build his engine and i think we got it right.
i think so too graham, but i also think theres loads more i can get out of the kit. im gonna switch out the estoril for your brothers boss this week sometime to see what that does, thatll be fun :-D
