Re: Polini 65 carb options?
Responsible Jon /
You need to get a Malossi or Polini 4 petal reed cage for Pugeot or MBK engines, they are the same bolt pattern. You have to trim some fins on the cylinder and the head, but you can fit a clamp on style PHBG onto them, or use a hose with a spigot style. I personally don't like anything bigger than 19mm, but others swear by 21mm.
