What type and size Carb is a good upgrade for a 78' FreeSpirit? Any suggestions?
Just the carb won't do much for performance. You can simply bore out your stock bing with a drill bit and boom, bigger carb. You will need to order several jets to find the right size to use afterwards. It's all in the wikki, and search is your friend!
Thanks.
Unfortunately, i am buying a new carb anyway. The old one is shit and has too many problems to mention. Any suggestions on a new carb that would help?
