Fmf fatty pipe on a qt50
so I know these pipes were made for the pw50 which, you all know isthe same engine as the qt so my question is would one of these fit on the qt. I am asuming the answer is no because I have never seen it done but I figured it was worth an ask?
Re: Fmf fatty pipe on a qt50
make it work
i will take that as a no... it wont work with out cutting and welding?
reshaping pipes should be pretty easy if you can have somebody weld. you just cut all the way around where you want it to go somewhere else and then weld it back on in a different direction.
should fit but it probably won't knowing mopeds.
it actually looks like it would work awesomw on a qt50.
it looks like it would work if you made your own stinger for the silencer. i would assume it would work, except for the footpegs. footpegs are automatically in the way no matter what you try to do. performance peds are meant to be ridden without feet i guess.
