jug vs. jug on an e50 bottom end, which one is better stock? how about modded?
a35 in both cases for sure!
I am working on this exact project right now. a35top + e50 bottom. I just need to make a new intake and figure out an exhaust for it.
can someone post a pic of an a35 topend for me? i've never seen one. why are you making a new intake?
I have a A35 top end on and e50 with a 15.15 Dellorto.. It's torquey as hell
hmm that might be cutting it close as far as clearence on my build... thanks for the pic!
i'm just looking for top speed, but you can't get there without torque
Above cylinder has done 50 with ease. Shaw's super bike has a ported a35 which does 65.
what's done to it? (one in pic) my "stock jug" e50 does 50 in two city blocks. and that's with it running out of gearing
anyone else have info on this?
zack, did you do any work on your piston?
the old secret was to use a 50cc TCCD puch piston which has high domed.
you actually do need a lot of torque to get to high speed garret.
yeah that's what i said. why would you want the domed piston?
more compression.
that's what i was thinking. i read in another post that high compression lowers maximum rpm? is that true? the head i'll be running is already high compression
garret, you're gonna need really long studs.
already got em. bored out the case and head to accept 7mm studs
