hello! would the 64cc polini kit bolt directly on to my '77 maxi or would I need to modify anything to get it to attach properly?
thanks!
thanks!
it'll never work!
bolts up fine, do some case matching to unlock some of its potential
yes, it'll bolt right on without modification. Like derek says, matching the case ports would help a lot, since the polini transfers are much bigger.
great, thanks!
It won't last long without a case matching if you rip on it, I'll let you know that right now!
no way!!! it'll be fine without case matching!!!!! don't worry dude.
Listen to Zach!
