Ordering sprockets! Help a fool out. Puch Magnum.
(Casserollers) Gregory B. /
Alright, I fixed my jetting problem and need some help:
Polini 64cc
15.8mm Bing
Boss exhaust
Uni filter
Stock e50 gearing
I want to hit a top speed of high 40's. What can I go with without completely killing my low-end?
What gearing do you guys run on a setup like this?
Help a fool out, I'm ordering some stuff tonight. Thanks.
Gregory
Re: Ordering sprockets! Help a fool out. Puch Magn
go with a 40 rear 15 front
64 polini
15mm bing
milled head
techno estoril exhaust
16 40 gearing
top gps'd speed - 51.3mph
gets up to high 40s in less than 2 blocks easily.
stock e50 case and jug
16mm dell
franco head
modified techno estoril
11 30 gearing
top gps 50ish
with air leaks and blown rings
hits top speed in two blocks
soon rebuild and higher front gearing
What's the stock gearing for the rear that it comes with for a Magnum XK?
Does it already have 40 rear?
that's what it should be
I can only pick between 15 and 17 on mopedshop.com.
Shit!
15 is fine...
14x40.
I'm still looking for that monstrous 56-tooth rear sprocket.
i have one, and a 54, 52, 50, 48, and 45
hint: motobecanes have the same sprocket bolt pattern as puch
11x56 gearing anyone?
http://farm4.static.flickr.com/3180/2781676295_c90de43d73.jpg!
oops!
what's the smallest motobecane rear?
11x56 is what I'm shooting for at the moment. I'm hoping to take the Magnum hillclimbing in November.
