Ok so I just bought a 94 Targa LX. I have money right now to buy everything I need. This is what I need help with.
These are my upgrades:
+Airsal 70cc Kit.
+SHA 16:16 Dellorto Lever Choke(Unless something better in a reasonable price range will do me better)
+Technigas Next R
+Looking for a Hi Flow Custom Airfilter? Need help
-I need help finding an offset intake so my hi flow air filter will correctly function. And so I wont have to drop my motor out to mess with my carb. Where is the best place to get one? I see Moped Junk Yard has the Offset Manifold and Injector. Do I need a new injector too? Or can I use the injector off the regular intake? Also will the 16mm SHA fit this manifold no problem? Or will I need to shave or add to the shim?
Just curious. Sorry, haven’t kitted anything yet and I want to do this right.
-Also, what jetting size do I need to start out with while breaking in this kit? I know a stock dellorto is a 52 or so. What jets do I need to change? Idle, Main, and Pilot? I’m new to the whole Up Jetting thing and I’m sort of confused. I know I don’t want to plug chop either. I’d rather run a little rich and deal with that.
-I also want to nix my oil tank. I don’t trust those oil pumps. So what do I do? Just drain the oil tank and pre mix as usual? Or do I have to remove the pump? If I can just drain it and leave the thing attached but pre mix in the gas tank, that would be awesome.
