I need to know what the appropriate amount of oil to gas mixture is needed for a tomos streetmate with a 24 tooth rear sprocket and a bi-turbo exhaust. As of right now i am running without the oil pump hooked up so the only oil the engine is getting is directly pre-mix, i plan on hooking the oil pump up as soon as i get a new one, so if you could give me 2 ratios, one for my moped without a oil pump, and one for it when i put the oil pump on, it would be appreciated. if it makes any difference either, i am running a 56 jet
