How bad is it a little of the nikasil plating flakes off of your 70cc tccd kit?
Depends on how much the little bit is. A 1mm spot won't kill you.
If it's on the edge of a port, take some fine sandpaper (Like grade 1000) and smooth it up, so your rings won't catch.
how did you manage to do that?
just smooth it out....i've done it before with great success.
I was trying to widen the intake port with a file. I thought it was going well, until I looked inside. It's more than a mm, but not huge. I'll get in there with some sand paper and see what I can do. The thing is brand new, I haven't even run it yet!
Go to harbor freight and get a set of really tiny files, or just borrow mine. It's a hell of a lot easier than trying to use sandpaper to chamfer edges.
Eric
Don't use sandpaper to chamfer. Sandpaper is only good to smooth out a lil chip in the wall, if it's big you'll need to file it like Eric said.
