Thanks guys for all the kind words, just happy it's all done. Now lets hope it holds together through the rest of the rally #knocks on wood# ran very well tonight.
I'll hopefully have some video clips up by some time next week, when the pipe hits and the carb slide is full open she is a fucking screamer.
"Great work, are you going to put some disks on that thing to stop it?"
If you look at the rear hub you will see 6 holes that are drilled and tapped into it. I have a bicycle disk that I modified to mount to those 6 holes. I wanted to get a rear disk setup and running to practice before i worked on a front disk. Kind of moth balled that part of the build till after the rally. The stock drums are working good and do a good job hauling the back down from speed, figure it has a lot to do with the bike weighing so little... Still need to get it onto a scale because I am curious to see what she weighs in at.
