I just bought a 1984 puch maxi. 2 hp!! it has a bi turbo on and everything else is stock. it goes 35 on the flats. i want to kit it to keep up with my friends moby!! whick kits are good and where would i get them?
Look in the wiki you will find what you need. And do some reading about kits.
Kstar wins, hands down. Unless you port a stock cylinder.
I opened up my intake and exaust ports today I lost a lot of low end but I am still running a 12mm carb and intake so we will see how it is when I get my 15mm intake and carb
The airsal kit for tomos a55 motors is honestly the BEST kit for your dollars. If you are willing to spend $200 on a kit, then spend it on this kit.
Kstar is good, but good luck finding them... they havent been made in a long time.
Will The airsal kit for tomos a55 fit a cobra direc bolt on????
Yes. they bolt up just fine
a dermal and a little know how. should keep up with your friends moby.
puch airsal is pretty good for being one of the cheapest out there
Don't just keep up with your friend's moby. Trounce that shit on a single gear ratio and show him whatfor. Variators= cheating
