moby clutch pulley
ryan VanIddeking /
There is one available on the rcv team, but are there any other options on where to buy one. I can't seem to figure out how to order from them, even with the online translators. Can anyone please help me?
Re: moby clutch pulley
Are you going to put that on a moby 7? thats will be a dangerous wheelie bike...hhaha. I dunno try la becanerie?
ryan VanIddeking /
no its going on a moby 50v. I am building an av10 on it from the ground up like davey.
I don't think davey went clutch pulley style if i recall. You should totally put that av10/clutchpulley/bracebar on the moby 7... anyhow, did you check la becanerie/ ebay.fr? good for those little moby gems.
i didn't go clutch pulley style yet. i will be getting one though.
i would like to highly advise against a performance variator with an idle clutch function, at least the er2 with the clutch function. they seem to have a tendency to not actually let your bike idle and make you spend more money on the clutch pulley anyway. plus, because of the way its set up, you have basically no low end. it isnt actually a clutch, its a bearing on the shaft and the variator grabbing the belt is the "clutch grabbing". horrible. i cant fathom why they designed it like that, but they did and i hate them for it.
at the risk of another flogging, i will say...
clutch pulleys suck, get a varioplus and tune your shit. if its your everyday ride you will regret getting that clutch pulley
Do you still have yours/ looking to sell?
davey, there are things you can do to make that Er2 run much better. Are you oiling it adequately? What belt are you running? I find a new 4l320 makes that variator really happy.
yeah, i have oiled it. the problem is the now low end thing. i dont like that it doesnt have a real clutch. hopefully the clutch pulley will do the trick. i have found that a 4L320 does work well and let it idle, but its still not super happy.
