will one of the easily fit on my QT50
cut and weld?
is that what needs to be done
will it bolt on no prob? No.
even if you did cut and weld the flange itself could be different what does yours look like?
Flange doesn't matter, you can weld the original flange to the performance exhaust.
As long as you can cut and weld, everything can be made to fit.
If the Bi-Turbo fits without modification, I don't know. Never had a QT
