So they have been getting worse and worse. Its kinda scary cuz i keep thinking there going to explode at any second.
IS this normal
do the springs need to be greased or something?
IS this normal
You need the fork stabilizer. It's like the bar that holds on the front fender, and keeps the two fork tubes compressing together.
its on there. I have everything you need. They are the magnum length don't know if that makes a differnce
creak?
like when i hit a bump or the springs move it creaks like metal moving sound. Maybe they need to be regreased?
Did you grease them when you installed them?
grease them! its all you have going for you. Smother them in that stuff.
in the same fashion as you would for your penis.
no i didn't grease them guess i'll be doing that saturday.
