which carb size to run
Was going to install a 21mm carb on my tomos a35 with a 70cc airsal kit and tecno estroil exhaust. i was wondering if i can run a 21mm carb or if i should run a 19mm carb to increase velocity entering the reed cage. which carb would be best 19?20?21?
Re: which carb size to run
If you plan to spend time in the lower half of your rpm range the 19 would be best
bigger is not always better for sure
