TCCD kit not running for long after new setup
I have a 70cc TCCD kit which I put on my e50 engine (Puch maxi)
I have a 19mm Dellorto PHBG racing carb, proma GP exhaust, malossi angled air filter, a kstar piston and ring
I have ported the case to match the kit and only really took metal out of the first 2 in and touched up to the back wall but didn't really take anything out.
I have adjusted the timing and first time I went to start her she started and ran for 20-30 seconds then I turned the lights on to check them and the kit died.
So I started her up again and turned on the horn and the kit died. So I checked the spark and it wasn't blue but yellow orange so I replaced the condenser. Now I have a good blue spark.
But, I can't seem to get her to run for anything longer than 20 seconds. I have adjusted my timing to every possible setting (in 4 hours I think I covered them all) I have tried a 66, 69, 70, 71, 74, 80 main jets (I have started big). And if I let it sit for a day then I can start it up for 10-20 seconds again.
My needle is on the 2nd from the top. I believe it is a w9. I have a choke lever and use that. I have tried starter fluid and it is a little better than the gas but not much, and it still won't run.
I have practically new points (4 months old and it has been sitting for 2 or so). I did accidentally chip the stator plate so there is a little metal missing by my top screw to hold it in. But when I tighten it the stator doesn't appear to move.
I believe my gas mixture is close to 35:1 (I started with 50:1 and then added some 2 cycle oil to make it richer) but since it wasn't exactly 5 gallons of gas in the container and I mainly just tried to make it a little richer I am unsure as to the exact mixture but it is close and I used less than what it would have taken 4-4 1/2 gallons to get there.
I have looked around and can't quite see anything on this specific problem. Maybe I am wrong. Thank you in advance.
Re: TCCD kit not running for long after new setup
Oh yeah, I have also installed all new bearings (and seals) and a brand new DMP crankshaft from treats
Check for airleaks, and do a plugchop to analyze your mixture.
Had a similar problem. I needed more air. pull the filter and see if it will run longer. But don't drive around like that.
Thank you for the reply!, I am sorry I forgot to post this...I have tried it with the air filter off as well as on.
I have also use the ultra grey permatex sealant to seal the case (which might have been a mistake...I can't seem to find yamaha bond anywhere...) and I used permatex red high temp gasket maker to seal the cylinder and the high compression head I have 2 gaskets on the base cylinder and 1 metal gasket on the head.
I tried it without the head gasket and it hits the high compression head, but it clears it just fine with the gasket.
I will try to post pics of my porting job, just for that to be analyzed.
Definately sounds like a jetting issue. Have you messes with the air mixture screen. ? It will not idle correctly without it being set in the right range. Will it run if you hold the throttle open, but not idle?
I have tried the side air mixture screw on almost every setting for all those jets mentioned.
And it will not run if I open the throttle either....at least I have tried to start it without the choke and then open the throttle and I think I may be flooding the engine when I do that....idk though.
I have even tried it with the choke on and open the throttle. I just can't quite seem to get her to really get a good start. The starts are rather weak.
lee's anus is leefungchowOG /
ditch the FUEL filter not air. might be a flow issue. thats what it sounds like to me.
also sounds like you need to RE-WIRE your bike!!!!!!!!! arg!!
My bike is wired the same way I had it running with before I changed everything out and replaced the condenser, with one exception.
The only difference is that the white (or green I can remember now) wire should go closer to the condenser than the black wire......would that have any effect?
Thanks for all the suggestions....I will try them and see what comes of it!
Here is a pic of my case matching job
<a href=" http://s11.photobucket.com/albums/a158/JesusRules4All/?action=view&current=IMGP0721.jpg" ; target="_blank"><img src=" http://i11.photobucket.com/albums/a158/JesusRules4All/IMGP0721.jpg" ; border="0" alt="e50 engine porting job"></a>
Sounds like a fuel delivery problem to me.
Take the carb off and remove the float bowl. Hook the fuel line back up and open the petcock. There should be a good solid flow of fuel until you raise the float with your finger, then the flow should totally stop.
Also, check the float level setting.
ok, I will try that!
update...I finally got the timing perfect with the points at about .016 inches and it ran just fine....although I noticed the magneto assembly (flywheel, magneto and that whole assembly) was really hot and the nut popped off
so I cinched it on and rode for about 30 minutes. And changed jets around....my smallest jet seems to be too big (66).
Oh yeah I also am using 1/2 fuel line......not sure if that matters but it is a good snug fit.
And anyways I noticed something was wrong and the moped wouldn't start again....so I took the flywheel off and saw that basically my woodruff key was too small and that the flywheel was moving without that woodruff key keeping it in place
I fixed that by making a woodruff key and it is snug in there now with no tolerance.
But my main problem is I think that either my stator plate is moving or my points are moving.
B/c once I get them set perfectly and I get 1 huge perfect spark then I won't be able to get any sparks.... until I reset it again.
I am thinking that nick out of my stator is allowing it to move since the screw only hold onto 1 side instead of being surrounded by material. The outside metal chunk fell off...
I have another engine which I will one day build back up but I am scavenging parts from it as I need them....
Thanks for all of your input!!!!!!!!
you're running a 66 mainjet in a 19 phbg?
that is like, turbo too small. you should be in the 80's i think. take a look at the moped tuners setup spreadsheet for a ballpark.
Well, the highest jet I currently have is an 80....and well I couldn't even get the moped to start with that. And it seemed to have a bog when I tried the 69 jet....like when I tried to throttle past half-throttle. Maybe it is just because I am extremely too small...idk, I will look into larger jets! thanks!
