question about the DIY reed valve kit
thefrightner ( john the man ) /
ok so i was reading about the do it yourself reed kit but like can it be done on a sachs 505 engine? and then also what would you do with the intake on the jug?
Re: question about the DIY reed valve kit
you block the intake off with a metal plate. id imagine you can do it on a 505, as long as it has a spot on it where you could mount your reed block thing.
