Ive done more work to share with the army Look. I will run this bitch to 50 if it kills me
I hope you do it.
mad porting?
are those stock reeds, just dremeled out?
i was looking at em too. but damn 60 bucks. fuck thats alot of money. thats what, 1/3 of the way to a imperial morini kit.
ima email you so we can share info'z on this...
get the racing reeds they are way bigger
Yeah I see that but then you have a rectangle shaped port ,and what intake will you use ? Will it cost 60 bucks too? Does one even exist ? where is it ? W T F
i have one but its plastic and its the same one hippy bought i think
The intake does not exist. This reed-valve fits a couple of motors. If I bought 100 of them it would cheaper.
Since I only had 4 mailed to me. More you buy of one unit the cheaper it is. The intake you modded looks good.
Ed
Well thanks Ed , but it actually One I made from scrach . It is currently running a Macuni But is ready for a del 19phbg since it does have an inside diamiter if 19mm as well. So soon I will have to get the del . Do any of you have a regular shop to buy these parts?
speak spanish know your engines as they came on everything and was named different in each country.
O they make 2 kits for the morini M1's..
Large port 65cc/ I think the case has to be weld
Small port 65cc/ direct bolt on
Yeah but that kinda voids the 50 50 , besides the Imperial kit is a nightmare and the other is in hiding.
how far are the bolts on the intake?
anyone care to do a quick measure?
Distance between them ?
yah..Im just trying to see if I could use other valves for a laura m56.
way different than the batavus, dude
man they exactly the same to me
never mind Im in space so dont mind me
nice project man, i like the work on the intake and reed cage.
Yeah well I do what I can . I just cant wait to throw a 19phbg del on there .Then it should really rip .
I don't remember morini case inducted cylinders... do they have the third transfer on the top? if not you need that or at least some boost ports
izzata stock pipe?
Not unless they came stock with a Biturbo.
This pacer is sick. My bike (magnum, MK65, 19phbg, boss pipe) is hitting low 50s, and I'll look over my shoulder and Rick is _right there_. Crazy.
